跳转到主内容
Samsung Glyde Antenna Replacement
你所需要的
  1. Samsung Glyde Antenna Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Antenna Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Antenna Replacement, Antenna: 步骤 3 中的图像 1,2 Samsung Glyde Antenna Replacement, Antenna: 步骤 3 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Antenna Replacement: 步骤 4 中的图像 1,2 Samsung Glyde Antenna Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap.
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Antenna Replacement: 步骤 5 中的图像 1,2 Samsung Glyde Antenna Replacement: 步骤 5 中的图像 2,2
    • The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends.
    • Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
  6. Samsung Glyde Antenna Replacement: 步骤 6 中的图像 1,2 Samsung Glyde Antenna Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
结论
Cameron Law
于10/12/11注册
142 声望
创作了5篇指南
团队
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G12
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,094
