跳转到主内容
Samsung Gear VR with Controller Motherboard Replacement
你所需要的
  1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: 步骤 1 中的图像 1,3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: 步骤 1 中的图像 2,3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: 步骤 1 中的图像 3,3
    • Turn the controller upside down to access the battery compartment.
    • The battery compartment is located on the opposite side of the buttons.
    • Press on the top of the battery plate and slide down to remove the cover.
  2. Samsung Gear VR with Controller Motherboard Replacement: 步骤 2 中的图像 1,3 Samsung Gear VR with Controller Motherboard Replacement: 步骤 2 中的图像 2,3 Samsung Gear VR with Controller Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the AAA batteries using your fingers.
  3. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: 步骤 3 中的图像 1,2 Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: 步骤 3 中的图像 2,2
    • Remove the four 5mm Phillips #000 screws.
  4. Samsung Gear VR with Controller Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the metal spudger to pry the back side of the controller apart from the front.
    • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
  5. Samsung Gear VR with Controller Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Gear VR with Controller Motherboard Replacement: 步骤 5 中的图像 2,2
    • Pull apart the two halves of the controller to access the motherboard.
  6. Samsung Gear VR with Controller Motherboard Replacement: 步骤 6 中的图像 1,3 Samsung Gear VR with Controller Motherboard Replacement: 步骤 6 中的图像 2,3 Samsung Gear VR with Controller Motherboard Replacement: 步骤 6 中的图像 3,3
    • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
    • Separate the motherboard and trackpad from the rear part of the controller.
结论
2等其他人完成本指南。
Jake Criscione
于01/24/19注册
587 声望
创作了3篇指南
团队
Cal Poly, Team S18-G3, White Winter 2019 Cal Poly, Team S18-G3, White Winter 2019 的会员
CPSU-WHITE-W19S18G3
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 953
