跳转到主内容
Samsung Gear VR with Controller Inner Mask Replacement
你所需要的
  1. Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 步骤 1 中的图像 1,3 Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 步骤 1 中的图像 2,3 Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: 步骤 1 中的图像 3,3
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Samsung Gear VR with Controller Inner Mask Replacement: 步骤 2 中的图像 1,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 2 中的图像 2,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 2 中的图像 3,3
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
  3. Samsung Gear VR with Controller Inner Mask Replacement: 步骤 3 中的图像 1,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 3 中的图像 2,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 3 中的图像 3,3
    • Use a metal spudger to remove the screw cover centered at the top.
  4. Samsung Gear VR with Controller Inner Mask Replacement: 步骤 4 中的图像 1,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 4 中的图像 2,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 4 中的图像 3,3
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
  5. Samsung Gear VR with Controller Inner Mask Replacement: 步骤 5 中的图像 1,2 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 5 中的图像 2,2
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
  6. Samsung Gear VR with Controller Inner Mask Replacement: 步骤 6 中的图像 1,2 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 6 中的图像 2,2
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
  7. Samsung Gear VR with Controller Inner Mask Replacement: 步骤 7 中的图像 1,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 7 中的图像 2,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 7 中的图像 3,3
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
  8. Samsung Gear VR with Controller Inner Mask Replacement: 步骤 8 中的图像 1,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 8 中的图像 2,3 Samsung Gear VR with Controller Inner Mask Replacement: 步骤 8 中的图像 3,3
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
结论
另外一个人完成了本指南。
Harumi Hokari
于01/24/19注册
243 声望
创作了2篇指南
团队
Cal Poly, Team S18-G3, White Winter 2019 Cal Poly, Team S18-G3, White Winter 2019 的会员
CPSU-WHITE-W19S18G3
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 278
