跳转到主内容
Samsung Gear VR With Controller Focus Wheel Replacement
你所需要的
  1. Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: 步骤 1 中的图像 1,3 Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: 步骤 1 中的图像 2,3 Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: 步骤 1 中的图像 3,3
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 2 中的图像 1,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 2 中的图像 2,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 2 中的图像 3,3
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
  3. Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 3 中的图像 1,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 3 中的图像 2,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 3 中的图像 3,3
    • Use a metal spudger to remove the screw cover centered at the top.
  4. Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 4 中的图像 1,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 4 中的图像 2,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 4 中的图像 3,3
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
  5. Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 5 中的图像 1,2 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 5 中的图像 2,2
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
  6. Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 6 中的图像 1,2 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 6 中的图像 2,2
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
  7. Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 7 中的图像 1,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 7 中的图像 2,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 7 中的图像 3,3
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
  8. Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 8 中的图像 1,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 8 中的图像 2,3 Samsung Gear VR With Controller Focus Wheel  Replacement: 步骤 8 中的图像 3,3
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
  9. Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: 步骤 9 中的图像 1,3 Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: 步骤 9 中的图像 2,3 Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: 步骤 9 中的图像 3,3
    • Remove the one 5mm Phillips #000 screw.
    • The screw for the focus wheel has a larger head than the rest of the screws.
    • Separate the focus wheel from the headset using your fingers.
结论
另外一个人完成了本指南。
Harumi Hokari
于01/24/19注册
243 声望
创作了2篇指南
团队
Cal Poly, Team S18-G3, White Winter 2019 Cal Poly, Team S18-G3, White Winter 2019 的会员
CPSU-WHITE-W19S18G3
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 276
