跳转到主内容
Samsung Gear VR USB Connector Replacement
  1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: 步骤 1 中的图像 1,1
    • Remove front cover from headset.
  2. Samsung Gear VR USB Connector Replacement: 步骤 2 中的图像 1,1
    • Slide the latch to the right to unlock the current connector.
    I do not have the latch to lock and unlock it, can I still swap out the USB ports? If so how? I've looked all over and have found nothing about the matter.
    Sophie - 回复
  3. Samsung Gear VR USB Connector Replacement: 步骤 3 中的图像 1,2 Samsung Gear VR USB Connector Replacement: 步骤 3 中的图像 2,2
    • Lift connector clip away from headset and towards you.
    • Slide current connector out and away from headset until it is disconnected from connector clip.
  4. Samsung Gear VR USB Connector Replacement: 步骤 4 中的图像 1,1
    • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
    • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
  5. Samsung Gear VR USB Connector Replacement: 步骤 5 中的图像 1,2 Samsung Gear VR USB Connector Replacement: 步骤 5 中的图像 2,2
    • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
    • Slide the lock latch to the left to secure the connector into place.
结论
3等其他人完成本指南。
Alfredo Aparicio
于09/25/17注册
313 声望
创作了3篇指南
团队
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G6
4 名成员
创作了7篇指南
5条评论
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - 回复
Were do I get the USB c adapter
helenpaul77 - 回复
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron -
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh -
Where can I get micro USB converter for gear vr not type c
Molefi Aaron - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 60
总计 16,360
