跳转到主内容
Samsung Gear VR Trackpad Replacement
你所需要的
  1. Samsung Gear VR Trackpad Replacement, Front Phone Mount: 步骤 1 中的图像 1,3 Samsung Gear VR Trackpad Replacement, Front Phone Mount: 步骤 1 中的图像 2,3 Samsung Gear VR Trackpad Replacement, Front Phone Mount: 步骤 1 中的图像 3,3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Trackpad Replacement: 步骤 2 中的图像 1,2 Samsung Gear VR Trackpad Replacement: 步骤 2 中的图像 2,2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR Trackpad Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR Trackpad Replacement: 步骤 4 中的图像 1,1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
  5. Samsung Gear VR Trackpad Replacement, Inner Mask: 步骤 5 中的图像 1,3 Samsung Gear VR Trackpad Replacement, Inner Mask: 步骤 5 中的图像 2,3 Samsung Gear VR Trackpad Replacement, Inner Mask: 步骤 5 中的图像 3,3
    • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
    • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
  6. Samsung Gear VR Trackpad Replacement, Trackpad: 步骤 6 中的图像 1,2 Samsung Gear VR Trackpad Replacement, Trackpad: 步骤 6 中的图像 2,2
    • Pry the trackpad sensor loose from the mask.
    • I found that prying the metal spudger underneath the small outcropping at the bottom of the sensor to be the easiest way to remove the piece.
结论
Alfredo Aparicio
于09/25/17注册
313 声望
创作了3篇指南
团队
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G6
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,027
