跳转到主内容
Samsung Gear VR Front Phone Mount Replacement
你所需要的
  1. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: 步骤 1 中的图像 1,3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: 步骤 1 中的图像 2,3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: 步骤 1 中的图像 3,3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Front Phone Mount Replacement: 步骤 2 中的图像 1,2 Samsung Gear VR Front Phone Mount Replacement: 步骤 2 中的图像 2,2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G6
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 12
总计 1,225
