跳转到主内容
Samsung Gear VR Motherboard Replacement
你所需要的
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 步骤 1 中的图像 1,3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 步骤 1 中的图像 2,3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: 步骤 1 中的图像 3,3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Gear VR  Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: 步骤 4 中的图像 1,1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
结论
David Forlano
于09/25/17注册
119 声望
撰写一个指南
团队
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G6
4 名成员
创作了7篇指南
一条评论
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,514
