跳转到主内容
Samsung Gear S3 Frontier Wristband Replacement
视频概述
  1. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: 步骤 1 中的图像 1,3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: 步骤 1 中的图像 2,3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: 步骤 1 中的图像 3,3
    • Place the watch screen-down so that its back cover is showing.
    • Use your nail to push the small silver ball bearing on the right side downward.
    • If your nails aren't sharp enough, you can use a sharp pointed object such as a toothpick or pen.
    • While the ball is pressed down, pull the wristband outwards until the strap is disconnected from the main frame.
    • For reassembly, hold the ball down and then wedge each pin on the wristband into the pin holes of the main frame.
    • Follow the same steps for the ball on the left side, except this time push the ball upwards and then pull outwards.
结论
2等其他人完成本指南。
Corey Rumbaugh
于10/08/18注册
1,507 声望
撰写一个指南
团队
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 的会员
CPSU-WHITE-F18S15G2
4 名成员
创作了34篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 42
总计 2,808
