跳转到主内容
Samsung Gear S3 Frontier Bezel Ring Replacement
你所需要的
  1. Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: 步骤 1 中的图像 1,3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: 步骤 1 中的图像 2,3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: 步骤 1 中的图像 3,3
    • Contains small springs and ball bearings. We suggest working over a plate or tray.
    • Hold the watch firmly in one hand, face up.
    • Place the iFixit Opening Tool under the bezel ring and use prying motion to remove.
    • The plastic retainer is manufactured with an open gap, you did not break it.
    • For reassembly, set the plastic retainer in the ring, then press the ring down until it snaps in place.
结论
26等其他人完成本指南。
Mark Iknoian
于10/08/18注册
1,027 声望
撰写一个指南
团队
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 的会员
CPSU-WHITE-F18S15G2
4 名成员
创作了34篇指南
42条评论
I got the bezel popped off to clean it. Now it wont pop back on! Help!
shileski - 回复
line up the bezel with the screen and push it in
Arthur -
I’ve tried lining it up with the screen and pushing it in about 50 times now and everytime I do it clicks, but after rotating it a few times the bezel locks and I can’t rotate it anymore. YES all the ball bearings are in the right place, YES the springs are in the right place. There’s this little plastic piece that I can’t tell if it goes inside the bezel piece or if it goes on top of the watch next to the ball bearings. I’m able to get the bezel back on when I put the little plastic piece on the bezel, it clicks right in, but it locks up. When I leave the little plastic piece on the watch I can’t get it to click in at all. I think I just royally f’ed up my watch!
Hardy T - 回复
did u manage to fix it?
Dave Green - 回复
Interested to know if anyone had much success with this process.
Seth Armour - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 96
过去 30 天: 395
总计 85,998
