跳转到主内容
Samsung Gear S3 Battery Replacement
你所需要的
视频概述
精选文档
  1. Samsung Gear S3 Battery Replacement, Removing Wrist Straps: 步骤 1 中的图像 1,2 Samsung Gear S3 Battery Replacement, Removing Wrist Straps: 步骤 1 中的图像 2,2
    • Locate the small push tabs on the back of the wrist straps, pushing them in to release the wrist strap.
    • Remove any casing or housing on the watch, and clean any dust/debris.
    • (Black lines are used for privacy)
  2. Samsung Gear S3 Battery Replacement, Removing Back Plate & Lifting Out: 步骤 2 中的图像 1,3 Samsung Gear S3 Battery Replacement, Removing Back Plate & Lifting Out: 步骤 2 中的图像 2,3 Samsung Gear S3 Battery Replacement, Removing Back Plate & Lifting Out: 步骤 2 中的图像 3,3
    • Using a Tri-point screwdriver, unscrew the four (4) back screws. Note: The case screws may remain in their place.
    • Using a metal jimmy, and a little bit of force, push down then lever it up to pop out the case.
  3. Samsung Gear S3 Battery Replacement, Detaching Ribbons: 步骤 3 中的图像 1,3 Samsung Gear S3 Battery Replacement, Detaching Ribbons: 步骤 3 中的图像 2,3 Samsung Gear S3 Battery Replacement, Detaching Ribbons: 步骤 3 中的图像 3,3
    • Detatch the three (3) ribbons carefully with a plastic spudger. The ribbons to detach is black, yellow, & blue. You should feel a little click when re-attaching later. Note: These parts are very delicate so exercise caution!
  4. Samsung Gear S3 Battery Replacement, Removing Motherboard: 步骤 4 中的图像 1,3 Samsung Gear S3 Battery Replacement, Removing Motherboard: 步骤 4 中的图像 2,3 Samsung Gear S3 Battery Replacement, Removing Motherboard: 步骤 4 中的图像 3,3
    • Prying up from the corner with the red arrow, lift the motherboard and maneuver the ribbons out of the opening making sure not to tug or rip them.
    • Remove two Phillips head screws before moving on.
  5. Samsung Gear S3 Battery Replacement, Splitting Motherboard from Battery Compartment: 步骤 5 中的图像 1,3 Samsung Gear S3 Battery Replacement, Splitting Motherboard from Battery Compartment: 步骤 5 中的图像 2,3 Samsung Gear S3 Battery Replacement, Splitting Motherboard from Battery Compartment: 步骤 5 中的图像 3,3
    • Make sure to have the two Phillips head screws completely removed before attempting the following steps.
    • Pressing on the small black plastic area will give you leverage to pull off the motherboard gently.
    • Do NOT flip the motherboard without first detaching the battery's ribbon. The motherboard will still be connected by a ribbon. Only the battery's ribbon will be detached (Marked by the red arrow in the second photo). Using a flat tool to get underneath the ribbon will lift it up allowing you to flip the motherboard over.
    • The original battery will most likely be attached to the motherboard. A spudger will be needed to detach the battery from the motherboard. Note: Use caution, gently inserting and lifting as it allows. Use of any sharp or pointed tools can rupture the battery and will cause it to burst.
  6. Samsung Gear S3 Battery Replacement, Replace Battery: 步骤 6 中的图像 1,1
    • Insert the new battery and test for power.
    • Remember to recycle your used batteries!
结论
11等其他人完成本指南。
Mister HD
于05/09/19注册
483 声望
撰写一个指南
5条评论
Not a comment but a question: What happens with the waterproofing of the watch with this?
Arthur Mize - 回复
Of course with a take apart of any device the waterproofing will be gone unfortunately.
Mister HD -
Id heavily consider rewriting step 4. I almost pried the board off with the screws still attached because I read from left to right on the pictures. Device is okay but I was assuming an entire unit attached with screws was coming out of a shell. Good guide otherwise, thanks
Mike Duffy - 回复
Question - Is this the same procedure for the Frontier model of the S3?
Michael Maxson - 回复
A bit of a challenge for someone at the age of 63. But it worked out. Screws should be off before lifting the mainboard (step 4).
Jens Hektor - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 151
过去 30 天: 764
总计 23,299
