跳转到主内容
Samsung Gear S2 Watch Strap Replacement
你所需要的
  1. Samsung Gear S2 Watch Strap Replacement, Watch Strap: 步骤 1 中的图像 1,2 Samsung Gear S2 Watch Strap Replacement, Watch Strap: 步骤 1 中的图像 2,2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Watch Strap Replacement: 步骤 2 中的图像 1,2 Samsung Gear S2 Watch Strap Replacement: 步骤 2 中的图像 2,2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Watch Strap Replacement: 步骤 3 中的图像 1,2 Samsung Gear S2 Watch Strap Replacement: 步骤 3 中的图像 2,2
    • Repeat the procedure from step 2 for the other strap.
结论
7等其他人完成本指南。
Jacob Baldwin
于02/20/17注册
3,412 声望
创作了5篇指南
团队
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S2G3
3 名成员
创作了23篇指南
6条评论
can you also provide instruction to change home button on Gear S2
thanks
inder kapoor - 回复
you have to buy the continuing transfunctioner to change the home button on the gear s2
i have some for sale if interested
bobby - 回复
Where can you buy new straps?
Olga Andreu - 回复
Ebay Amazon etc.
Jens Troemer - 回复
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
Ryo Kimball - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 67
总计 9,234
