简介
手表带上的扣是否已损坏?或者您是否想用定制手表带替换原厂表带?那就来吧!
你所需要的
用手指向前推动释放卡扣,同时拉起表带。
The bracelet should be removed first!
Das Armband sollte zuerst entfernt werden!
即将完成!
请倒序重组你的设备。
结论
请倒序重组你的设备。
7等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
6条评论
can you also provide instruction to change home button on Gear S2
thanks
Where can you buy new straps?
Ebay Amazon etc.
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
The warning to turn off the watch to avoid electrical shock was a joke, right?!
nanev - 回复
The screws don't seem to be turning easily. What's the best way to loosen them without stripping them?
Mark Franz - 回复
I’m going to be shocked by a dead 3.8V battery? Of course, only if the watch is powered on. Ridiculous statements like this do not reflect positively on the credibility of this entire procedure. If the author seriously thinks this is a danger then I question your basic understanding of electronics.
Alex Tatistcheff - 回复
… to avoid being shocked when you lose your data! :)
Reuben Janzen-Martin - 回复
