跳转到主内容
Samsung Gear S Microphone Replacement
你所需要的
  1. Samsung Gear S Microphone Replacement, Display Assembly: 步骤 1 中的图像 1,3 Samsung Gear S Microphone Replacement, Display Assembly: 步骤 1 中的图像 2,3 Samsung Gear S Microphone Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Microphone Replacement: 步骤 2 中的图像 1,2 Samsung Gear S Microphone Replacement: 步骤 2 中的图像 2,2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
  3. Samsung Gear S Microphone Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
  4. Samsung Gear S Microphone Replacement: 步骤 4 中的图像 1,1
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Microphone Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Microphone Replacement: 步骤 6 中的图像 1,1
    • Now the watch should be in three separate pieces.
  7. Samsung Gear S Microphone Replacement, Microphone: 步骤 7 中的图像 1,1
    • Locate the microphone on the lower right corner of the plastic motherboard assembly .
  8. Samsung Gear S Microphone Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to lift up the microphone ribbon connector.
  9. Samsung Gear S Microphone Replacement: 步骤 9 中的图像 1,1
    • Use the spudger to lift up the white microphone circuit board.
结论
3等其他人完成本指南。
Luis Franco
于09/03/15注册
1,076 声望
创作了4篇指南
团队
USF Tampa, Team 12-1, Blackwell Fall 2015 USF Tampa, Team 12-1, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G1
4 名成员
创作了5篇指南
3条评论
ok. thanks a lot but one stupid question where can i buy a new microphone?
amir arya - 回复
any chance of posting were to buy a new mic please..
ian stapleton - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 2,275
