跳转到主内容
Samsung Gear S Home Button Assembly Replacement
你所需要的
  1. Samsung Gear S Home Button Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,3 Samsung Gear S Home Button Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,3 Samsung Gear S Home Button Assembly Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Home Button Assembly Replacement: 步骤 2 中的图像 1,2 Samsung Gear S Home Button Assembly Replacement: 步骤 2 中的图像 2,2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
  3. Samsung Gear S Home Button Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
  4. Samsung Gear S Home Button Assembly Replacement: 步骤 4 中的图像 1,1
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Home Button Assembly Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Home Button Assembly Replacement: 步骤 6 中的图像 1,1
    • Now the watch should be in three separate pieces.
  7. Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: 步骤 7 中的图像 1,2 Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: 步骤 7 中的图像 2,2
    • Locate the home ribbon connector attached to the wrist side (side that faces the user when wearing it) of the motherboard assembly.
    • Locate the home ribbon assembly attached to the screen side of the motherboard assembly.
  8. Samsung Gear S Home Button Assembly Replacement: 步骤 8 中的图像 1,1
    • Use a plastic opening tool to gently pry up on the home ribbon connector.
  9. Samsung Gear S Home Button Assembly Replacement: 步骤 9 中的图像 1,1
    • Use the spudger to pry up the home ribbon assembly.
结论
2等其他人完成本指南。
Luis Franco
于09/03/15注册
1,076 声望
创作了4篇指南
团队
USF Tampa, Team 12-1, Blackwell Fall 2015 USF Tampa, Team 12-1, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G1
4 名成员
创作了5篇指南
2条评论
where can i buy the home buton?
Hanna Iskandar - 回复
I am in search of the SM-R750v Housing Back Cover, any suggestions
Rita Arnold - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 5,169
