跳转到主内容
Samsung Gear S Display Assembly Replacement
你所需要的
  1. Samsung Gear S Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,3 Samsung Gear S Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,3 Samsung Gear S Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Display Assembly Replacement: 步骤 2 中的图像 1,2 Samsung Gear S Display Assembly Replacement: 步骤 2 中的图像 2,2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
  3. Samsung Gear S Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
  4. Samsung Gear S Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Display Assembly Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Now the watch should be in three separate pieces.
结论
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
19等其他人完成本指南。
团队
USF Tampa, Team 12-1, Blackwell Fall 2015 USF Tampa, Team 12-1, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G1
4 名成员
创作了5篇指南
16条评论
Where can i get the LCD for Gear S
Kuek See Chuan - 回复
my screen flashing light and show on screen lines
avi mor - 回复
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
Mark Measures - 回复
My watch is doing the same thing. Did you get a fix for it?
steve Walks -
There are flashing yellow lights on the screen, could I fix that?
Alex - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 17
总计 15,500
