简介
The watchband on the Samsung Gear Live is user-replaceable. If the band breaks or if you’d like to use a different band, follow these steps.
你所需要的
Press the watchband down against the work surface.
Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
With the spring-loaded pin pressed in, the watch band should release easily.
Gently pull the band away from the body of the watch.
Repeat steps 2 and 3 for the opposite side.
2等其他人完成本指南。
