跳转到主内容
Samsung Gear Live Motherboard Replacement
你所需要的
  1. Samsung Gear Live Motherboard Replacement, Lay the watch face-down: 步骤 1 中的图像 1,1
    • Lay the watch face-down on a flat, stable surface.
  2. Samsung Gear Live Motherboard Replacement, Remove the holding pin: 步骤 2 中的图像 1,1
    • Press the watchband down against the work surface.
    • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
  3. Samsung Gear Live Motherboard Replacement, Remove the watchband: 步骤 3 中的图像 1,1
    • With the spring-loaded pin pressed in, the watch band should release easily.
    • Gently pull the band away from the body of the watch.
    • Repeat steps 2 and 3 for the opposite side.
  4. Samsung Gear Live Motherboard Replacement, Locate the four screws: 步骤 4 中的图像 1,1
    • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
  5. Samsung Gear Live Motherboard Replacement, Remove the 4 screws: 步骤 5 中的图像 1,1
    • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
  6. Samsung Gear Live Motherboard Replacement, Pry off the back of the watch.: 步骤 6 中的图像 1,1
    • Gently work the plastic opening tool under the top edge of the watch’s back cover.
  7. Samsung Gear Live Motherboard Replacement, Lift off the back cover: 步骤 7 中的图像 1,2 Samsung Gear Live Motherboard Replacement, Lift off the back cover: 步骤 7 中的图像 2,2
    • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
  8. Samsung Gear Live Motherboard Replacement, Set both halves of the watch aside: 步骤 8 中的图像 1,1
    • Lay both halves of the watch body assembly face down (with internal components facing up).
  9. Samsung Gear Live Motherboard Replacement, Pry away the ribbon cable: 步骤 9 中的图像 1,2 Samsung Gear Live Motherboard Replacement, Pry away the ribbon cable: 步骤 9 中的图像 2,2
    • Locate the ribbon cable connector near the edge of the watch's case.
    • Using the plastic opening tool, gently pry the connector from the motherboard
  10. Samsung Gear Live Motherboard Replacement, Remove the red spacers: 步骤 10 中的图像 1,2 Samsung Gear Live Motherboard Replacement, Remove the red spacers: 步骤 10 中的图像 2,2
    • Using the plastic opening tool, gently pry away the red spacers.
    • Set the spacers aside.
  11. Samsung Gear Live Motherboard Replacement, Pry up the motherboard: 步骤 11 中的图像 1,3 Samsung Gear Live Motherboard Replacement, Pry up the motherboard: 步骤 11 中的图像 2,3 Samsung Gear Live Motherboard Replacement, Pry up the motherboard: 步骤 11 中的图像 3,3
    • Insert the end of the plastic opening tool under the motherboard.
    • Gently pry up the motherboard.
结论
2等其他人完成本指南。
Keith Cooper
于09/25/14注册
1,241 声望
创作了6篇指南
团队
USF Tampa, Team 1-7, Brown Fall 2014 USF Tampa, Team 1-7, Brown Fall 2014 的会员
USFT-BROWN-F14S1G7
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 848
