你所需要的
Place your thumbs on the ends of the screen.
Push the watch outward while pulling the band away from the watch.
Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
Gently peel the screen assembly up and away from the device using tweezers.
gear fit 2 screen assembly is very expensive at the moment at 135 USD + 10USD shipping… looks like you are buying a whole new unit, ridiculous… i am planning to buy a new GF2 and have my defective GF2 to be source of spare parts in the future ( battery, hear rate sensor, circuit board, etc..) or maybe wait some time till prices go down.
17等其他人完成本指南。
28条评论
Where can you buy replacement screen?
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
Where to find the replacement screen?
Ok Kudus to the Author! I was able to purchase a screen off of ebay for 40 bucks, followed your instructions and have my watch back! Thank you
Where did you find the screen/digitizer?
Why would you get a screen for 40 Bucks?? I found a used Gear fit in better condition then mine and was 6 dollars cheaper!
IFIXIT is very nice, but where can I buy the spare parts?
were can i buy the screen?
hi, where i can buy screen gear fit?
How to reassemble? What kind of adhesive should I use?
my activity screens are blank...says "unable to load data..tap to retry" nothing after I tap.
need screen for samsung gear fit 2 black ..my screen crashed for some reason !!! can you let me know where i can order that ?
I need a samsung gear fit screen
I need a samsung gear fit screen ...how can I?
Do you have a contact number please?
would this work with gear fit 2 watch??
No, the Gear Fit 2 is disassembled via 4 screws on the back of the device under small four rubber caps. I learned the hard way
Hello,
Your best bet is Ebay. I found one for around $35.00, but there are preowened gear fit 2 for cheaper than that. I guess it would for sure be your call if you would like to fit it or not.
Where can I get the screen?
Has anyone found out where you can purchase a screen at?
I think my Gear Fits screen wasnt working cuz upon opening it, I noticed large amounts of cocaine residue.
You guys can get the screen from joesge.com. Also, there are screws hidden on the bottom. This is an alternate way of opening it, but will require a Philips Head Screwdriver.
John Clark - 回复
but how to you know how much it costs
