简介
This guide will walk you through the process of replacing a broken or defective speaker in a Samsung Gear 2.
你所需要的
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
在这个步骤中使用的工具:Tweezers$4.99
Using tweezers, lift the rectangular speaker from the case.
4等其他人完成本指南。
3条评论
what happens if I don't put the speakers back?
Where can I buy the speaker?
