简介
If your speaker begins to fail, or if it no longer works, then this guide will help in show you step-by-step instructions on replacing the speaker. The speaker has some extra insulation to hold the speaker in place. This is a 4 out of 10 and should take at most 10 minutes to replace.
你所需要的
Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
Using the fine tweezers, pull up on the speaker ribbon cable until separated from the back cover. Make sure to approach it like in the picture otherwise it may not come off cleanly.
To lift out the speaker, place the tweezers underneath the speaker at the top left corner of the speaker and pry it up.
