跳转到主内容
Samsung Gear 2 Neo Battery Replacement
你所需要的
  1. Samsung Gear 2 Neo Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
  2. Samsung Gear 2 Neo Battery Replacement: 步骤 2 中的图像 1,2 Samsung Gear 2 Neo Battery Replacement: 步骤 2 中的图像 2,2
    • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
  3. Samsung Gear 2 Neo Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
  4. Samsung Gear 2 Neo Battery Replacement: 步骤 4 中的图像 1,2 Samsung Gear 2 Neo Battery Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
    • Avoid damaging the gold terminals on the ribbon cable.
    • When reassembling, make sure that the yellow strip snaps back on to the black pin.
    • The pin is located, and marked on the picture.
    • Pull up on the tab that says, “Pull”, the battery will lift straight out.
结论
10等其他人完成本指南。
Victor Yore
于08/27/15注册
705 声望
创作了5篇指南
团队
USF Tampa, Team 5-6, Blackwell Fall 2015 USF Tampa, Team 5-6, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G6
3 名成员
创作了5篇指南
7条评论
How so I change or repair the gold terminals
Prez - 回复
How do I repair or replace gold terminals
Prez - 回复
Did you ever find out how to repair those can I have the same problem ?
Brya -
I’m not sure why the comment was lost in my inbox. To answer the question regard the gold charging pins, the ones visible in step 2 for the first picture, you’d have to slide a pair of tweezers underneath the blue chip the one seen in step 4. this is dangerous as it’s more integrated to the case than the other parts. At that point you’d need to find a replacement pin set. I haven’t personally worked with the watch for sometime as i no longer have it due to the fact it needed to be returned. In other words this is only a best guess from my experience working with the watch. You might need to unhook the gold tab underneath the blue chip to give yourself a little extra room.
Adam Jeranek - 回复
If my gear 2. Neo is being inside water and switching on the display is blurry sounds are working but I cannot see a digital screen what should I do to fix it
Arjun Singh Rathod - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 6,715
