简介
Regular use and wear often leaves devices with rechargeable batteries, like the Gear 2 Neo, with a shorter than average battery life (if any at all). If this sounds like your device, then you've come to the right place. Today we'll be replacing the 300mAh battery that powers the Samsung Gear 2 Neo.
Follow along closely, and you'll have your smartwatch back up and charging in about 15 minutes.
你所需要的
To remove the Gear 2 Neo's watch band, start by locating the small metal levers on either end of the band.
Using your finger, push downward on the lever to release the band locking mechanism.
Continue to hold the lever down and pull the end of the band away from the watch to completely detach it.
Repeat this process for the other side of the band to fully release it.
Start by removing the four Torx T5 Security Screws from the back panel of the Watch Assembly.
Once the four Torx screws have been removed from the Watch Assembly, using a spudger, gently pry the front and back halves of the watch away from each other. This is best accomplished by placing the head of the spudger in the space between the two halves and rotating the head until the two halves split apart.
Once the two halves have separated simply lift the back half up and away from the front half to complete this step.
Once separated, the back half of the device is easily distinguished from the front by the large white battery. Take a moment to familiarize yourself with the important components presented in this half of the device before continuing.
300 mAh Battery
Battery Connector (attached by way of adhesive)
Device Speaker.
To remove the battery, simply use the provided tab labeled "pull" to separate the battery from the casing. Do not pull the battery all the way out quite yet; there is still the matter of detaching the battery connector.
Finally, using a spudger, separate the end of the battery connector cable, (held in place by another small application of adhesive and a plastic pin) from the casing.
另外一个人完成了本指南。
