简介
In this repair guide, you will be shown how to replace the motherboard.
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
Locate the rectangular metal connector that attaches the camera to the Gear.
Use tweezers to gently lift and detach the metal plate of the connector.
Use tweezers to grab and then gently lift up the metal plate of the safety belt.
7等其他人完成本指南。
一条评论
Can I send my gear 2 to you to repair the contacts on the back of the watch? The R380 cradle is in perfect shape the contacts on the watch has one contact worn and it will not charge help butchmcleod@hotmail.com
