跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will walk you through the process of replacing a broken camera in a Samsung Gear 2.
  1. Before disassembling your Gear, be sure it is powered off. To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components. Pry the device open from the other side also if it does not fully disassemble from one side. Pry the device open from the other side also if it does not fully disassemble from one side.
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Locate the rectangular metal connector that attaches the camera to the Gear. Use tweezers to gently lift and detach the metal plate of the connector.
    • Locate the rectangular metal connector that attaches the camera to the Gear.
    • Use tweezers to gently lift and detach the metal plate of the connector.
    • When reassembling the Gear, reattach the camera connector by carefully aligning the metal plate and its pins to its original placement. Make sure it snaps in place to avoid improper connections and possible damage.
  5. Use tweezers to carefully lift the camera from its slot out of the case.
    • Use tweezers to carefully lift the camera from its slot out of the case.
    Cool! But were can i buy a camara for the watch?
    jorge - 回复
    Did you find a place to buy the camera? Mine broke today
    warakurna -
结论
2等其他人完成本指南。
Allison Michel
于2014年04月14日注册
513 信誉积分
创作了3篇指南
团队
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G27
4 名成员
创作了6篇指南
Hey cool! Were can i buy the camara?
jorge - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 4
总计 3,467
