跳转到主内容
加入维修社区 - 创建账户
Samsung Gear 2 Camera Replacement
你所需要的
    1. Samsung Gear 2 Camera Replacement, Front half and Back half: 步骤 1 中的图像 1,2 Samsung Gear 2 Camera Replacement, Front half and Back half: 步骤 1 中的图像 2,2
      • Before disassembling your Gear, be sure it is powered off.
      • To remove each strap, locate the metal latches on both sides of the back of the Gear.
      • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
      询问修复机器人
      添加评论
    2. Samsung Gear 2 Camera Replacement: 步骤 2 中的图像 1,1
      • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
      询问修复机器人
      添加评论
    3. Samsung Gear 2 Camera Replacement: 步骤 3 中的图像 1,3 Samsung Gear 2 Camera Replacement: 步骤 3 中的图像 2,3 Samsung Gear 2 Camera Replacement: 步骤 3 中的图像 3,3
      • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
      • Pry the device open from the other side also if it does not fully disassemble from one side.
      询问修复机器人
      添加评论
    1. Samsung Gear 2 Camera Replacement, Camera: 步骤 4 中的图像 1,2 Samsung Gear 2 Camera Replacement, Camera: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Locate the rectangular metal connector that attaches the camera to the Gear.
      • Use tweezers to gently lift and detach the metal plate of the connector.
      • When reassembling the Gear, reattach the camera connector by carefully aligning the metal plate and its pins to its original placement. Make sure it snaps in place to avoid improper connections and possible damage.
      询问修复机器人
      添加评论
    2. Samsung Gear 2 Camera Replacement: 步骤 5 中的图像 1,1
      • Use tweezers to carefully lift the camera from its slot out of the case.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G27
4 名成员
创作了18篇指南
1指南评论
Hey cool! Were can i buy the camara?
jorge - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 42
总计 4,131
