跳转到主内容
Samsung Galaxy a20e Charging Board Replacement
你所需要的
  1. Samsung Galaxy a20e Charging Board Replacement, Remove the SIM card tray: 步骤 1 中的图像 1,1
    • Insert a SIM eject tool, a SIM eject screwdriver tip, or a straightened paperclip into the small hole on the SIM tray on the left side of the phone.
    • Press firmly with the eject tool to eject the SIM card tray.
    • Remove the SIM card tray.
    • When putting the cards back in place, be sure they are correctly oriented inside the tray.
  2. Samsung Galaxy a20e Charging Board Replacement, Cut the screen adhesive: 步骤 2 中的图像 1,3 Samsung Galaxy a20e Charging Board Replacement, Cut the screen adhesive: 步骤 2 中的图像 2,3 Samsung Galaxy a20e Charging Board Replacement, Cut the screen adhesive: 步骤 2 中的图像 3,3
    • Heat the screen surface by using a hairdryer or the iOpener.
    • Lift the display by using a suction cup in order to create a little gap between the phone back cover and the display.
    • Insert a opening pick or a thin tool in the gap and slide it along the entire edge to cut the adhesive.
    • Lift the display with the help of the suction cup to separate the display from the back cover.
  3. Samsung Galaxy a20e Charging Board Replacement, Removal of the charging board cover: 步骤 3 中的图像 1,2 Samsung Galaxy a20e Charging Board Replacement, Removal of the charging board cover: 步骤 3 中的图像 2,2
    • Remove the seven Philips #00 screws.
    • Remove the charging board cover.
  4. Samsung Galaxy a20e Charging Board Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy a20e Charging Board Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy a20e Charging Board Replacement: 步骤 4 中的图像 3,3
    • Disconnect the connector that connects the logic board.
    • Disconnect the white wire.
    • Disconnect the blue wire.
    • Unscrew the Philips #00 screw.
  5. Samsung Galaxy a20e Charging Board Replacement, Charging Board Removal: 步骤 5 中的图像 1,2 Samsung Galaxy a20e Charging Board Replacement, Charging Board Removal: 步骤 5 中的图像 2,2
    • Remove the charging board and replace it with the new one.
结论
In order to reassemble your device, follow the instructions in reverse order.
另外一个人完成了本指南。
由衷感谢以下译者:
it en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Smilzo
于11/09/13注册
12,083 声望
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 534
