跳转到主内容
Samsung Galaxy View Kickstand Replacement
你所需要的
  1. Samsung Galaxy View Kickstand Replacement, Kickstand: 步骤 1 中的图像 1,1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Kickstand Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy View Kickstand Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy View Kickstand Replacement: 步骤 2 中的图像 3,3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
结论
5等其他人完成本指南。
Jordan Thayer
于10/06/16注册
535 声望
创作了2篇指南
团队
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G5
4 名成员
创作了12篇指南
15指南评论
Where do u buy a replacement kickstand
Bethann Stokes - 回复
The only thing I could find was a broken one on eBay for parts ......
cindylou73 -
I have the same issue! kickstand broke in half (it fell and got broken) and cannot find replacement
Carlos Sierra -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 43
总计 9,146
