跳转到主内容
Samsung Galaxy TabPro S Screen Replacement
你所需要的
  1. Samsung Galaxy TabPro S Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Apply heat around the screen to loosen the glue holding in the screen. A heat gun would be preferable as it needs to get relatively warm.
  2. Samsung Galaxy TabPro S Screen Replacement: 步骤 2 中的图像 1,1
    • Attach the small suction cup near the edge of the screen.
    • Pry in between the screen and the frame with a plastic spudger.
    • Pull up with the suction cup while prying and the screen should begin gently disconnecting.
    • Use the spudger on all edges of the tablet between the screen and the frame.
    • The screen should release.
  3. Samsung Galaxy TabPro S Screen Replacement: 步骤 3 中的图像 1,1
    • Disconnect the thick cable from the motherboard
    • Disconnect the golden cable from the motherboard
结论
另外一个人完成了本指南。
Mitchell Caister
于03/31/22注册
328 声望
创作了3篇指南
团队
IUPUI, Team 3-4, Harley Spring 2022 IUPUI, Team 3-4, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S3G4
3 名成员
创作了3篇指南
一条评论
Where to find a replacement screen for a 2017 Samsung tab S pro 12 inch ?!?!?
ori gosi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 759
