跳转到主内容
Samsung Galaxy TabPro S Front-Facing Camera Replacement
你所需要的
  1. Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: 步骤 1 中的图像 1,2 Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: 步骤 1 中的图像 2,2
    • Remove the back of the tablet by prying the plastic back using a flat tool.
    • When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
  2. Samsung Galaxy TabPro S Front-Facing Camera Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Once the back has been removed, disconnect all cables using a pair of tweezers to avoid damaging any components.
    • Once the cables have been disconnected, remove the battery using a flat plastic tool (not the metal spudger).
  3. Samsung Galaxy TabPro S Front-Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
    • Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
  4. Samsung Galaxy TabPro S Front-Facing Camera Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
    • Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
  5. Samsung Galaxy TabPro S Front-Facing Camera Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: 步骤 5 中的图像 2,2
    • Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
结论
Mitchell Caister
于03/31/22注册
328 声望
创作了3篇指南
团队
IUPUI, Team 3-4, Harley Spring 2022 IUPUI, Team 3-4, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S3G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 264
