跳转到主内容
Samsung Galaxy Tab S2 Screen Replacement
你所需要的
  1. Samsung Galaxy Tab S2 Screen  Replacement, Screen: 步骤 1 中的图像 1,1
    • Working on your device while it is turned on may result in an electric shock. Be sure to shut down and unplug your device before you begin.
    • Removing the screen may be difficult due to strong adhesives.
    • Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 Screen  Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab S2 Screen  Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
    • Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
    • Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
    • A ribbon cable is attached to the back of the screen. Avoid lifting or moving the screen more than 3-4 inches before disconnecting the ribbon cable or you could damage the device.
  3. Samsung Galaxy Tab S2 Screen  Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • A piece of silver tape is placed over the gold ribbon cable connecting the screen to the tablet.
    • Use the tweezers to carefully remove the silver tape.
  4. Samsung Galaxy Tab S2 Screen  Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab S2 Screen  Replacement: 步骤 4 中的图像 2,2
    • With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
结论
31等其他人完成本指南。
Jovina Martinez
于01/20/16注册
2,099 声望
创作了7篇指南
团队
USF Tampa, Team 10-4, Remmell Spring 2016 USF Tampa, Team 10-4, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G4
4 名成员
创作了18篇指南
15条评论
How about removing just the screen from the digitizer
nevillenicol - 回复
I agree, is removing the glass from the digitizer similar to samsung phones like the s4 and s5?
bhayden75 - 回复
Where do you get a new screen if the one you have is cracked
aleclittlelebronjameson - 回复
You can get a screen from Ebay or do a Google search. But the cost is half the cost of the tablet. So its around $200+
jamarjynr -
Actually I found that your could buy a non damaged tablet working fully for $150 USD and it was/is $259 for the complete screen assembly. So basically it's $100 cheaper if you just buy another tablet than it is to buy a replacement screen for the SM-T810. Ridiculous I know. I let the seller of the screen know about his silly price (in a nice way) but he would not budge. I also could not find any other listing on ebay or Amazon for that model he was the only seller with that part. It's better to just curse the tablet and move on and buy a newer tablet which would likely cost less and do more than the tab 2
machv5 -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 116
总计 61,924
