跳转到主内容
Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement
你所需要的
  1. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the tablet before disassembly.
    • Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
  2. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 2 中的图像 2,2
    • The glue is now melted, so using the metal spudger shown, pry open all sides of the tablet.
    • When prying open near the home and touch screen buttons, use a suction cup.
    • Do not stick the metal spudger past these buttons as this may damage your device.
  3. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 3 中的图像 2,2
    • Carefully lift up the screen.
    • There is a ribbon cable attached. Lifting the screen too quickly can damage the cable.
  4. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 4 中的图像 3,3
    • Remove the ribbon cable using the Metal Spudger.
    • The ribbon may be taped underneath to the grey frame. Gently lift the ribbon to untape it.
  5. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 5 中的图像 2,2
    • Remove all seventeen 3 mm screws using a PH000 Phillips screwdriver.
  6. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 6 中的图像 3,3
    • Lift the black frame using the two Metal Spudgers shown.
    • On the third picture, there is a Sim Card component that is connected to the frame and back cover. As you lift up the frame, it'll detach. This is normal.
  7. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 7 中的图像 1,1
    • Once lifted, flip the grey frame over.
    • This component connects to the sim card.
    • Remember to click this component back into place when reassembling the tablet.
  8. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Battery: 步骤 8 中的图像 1,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Battery: 步骤 8 中的图像 2,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Battery: 步骤 8 中的图像 3,3
    • Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
    • Remove the four black 3mm screws using a PH000 Phillips screwdriver.
  9. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 9 中的图像 1,1
    • Hold the frame and pop the battery off from the other side.
  10. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Home Button: 步骤 10 中的图像 1,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Home Button: 步骤 10 中的图像 2,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Home Button: 步骤 10 中的图像 3,3
    • This is where the ribbon cable for the home button is located.
  11. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 11 中的图像 1,1
    • Unclip the blue ribbon cable using the Blunt ESD Tweezer.
  12. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 12 中的图像 3,3
    • Carefully push the cable through the hole to the other side of the frame.
  13. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 13 中的图像 1,1
    • Using the pointed ESD Tweezer, lift up the silver tape.
  14. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 14 中的图像 1,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 14 中的图像 2,3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 14 中的图像 3,3
    • Using your thumb, push the home button to the right and lift up to dislodge it.
  15. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: 步骤 15 中的图像 2,2
    • Peel the ribbon cable off carefully, it may be glued to the grey frame.
    • Lift the home button.
结论
团队
USF Tampa, Team S2-G4, Sullivan Spring 2017 USF Tampa, Team S2-G4, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S2G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 1,353
