跳转到主内容
Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: 步骤 2 中的图像 1,1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 4 中的图像 1,2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 4 中的图像 2,2
    • Gently pry the camera connector away from the motherboard with a plastic opening tool or your fingers.
    • Lift the rear-facing camera module up and away from the device.
结论
2等其他人完成本指南。
Trent Chapman
于10/01/15注册
1,378 声望
创作了3篇指南
团队
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G15
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 1,416
