跳转到主内容
Samsung Galaxy Tab S 8.4 Micro USB Port Replacement
你所需要的
  1. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: 步骤 1 中的图像 1,2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: 步骤 2 中的图像 1,1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: 步骤 4 中的图像 1,2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: 步骤 4 中的图像 2,2
    • Remove the two 4 mm Phillips #000 screws securing the micro USB port.
  5. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, disconnect the charge port from the motherboard.
    • Once disconnected, lift to remove the charging port.
结论
32等其他人完成本指南。
Trent Chapman
于10/01/15注册
1,378 声望
创作了3篇指南
团队
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G15
4 名成员
创作了12篇指南
6条评论
It is so amazing and it works!
alva chan - 回复
Thanks a lot!
You make me a big economy by doing this myself with YOUR instructions !
Raphael
refelo123 - 回复
What model number is this device specifically? It says WiFi, but I have the same one from a network carrier. Would this charging port work for that? Model sm-707v is the one that I have.
tailoredtoteach - 回复
Thanks for the instructions, it looks simple , so I ordered the docking assembly and I replace it by myself.
You saved me a lot of money, thanks again!
wim-zelf - 回复
With these instructions I ordered part from Amazon and replaced charging port and tablet charges again. Thanks!
Philip Holly - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 51
总计 15,348
