跳转到主内容
Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement
你所需要的
  1. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: 步骤 1 中的图像 1,2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 步骤 2 中的图像 1,1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: 步骤 4 中的图像 1,2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: 步骤 4 中的图像 2,2
    • Remove the two 2 mm Phillips #000 securing the headphone jack.
  5. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 步骤 5 中的图像 1,1
    • Disconnect the blue connector by gently popping it off of the motherboard with a plastic opening tool.
  6. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 步骤 6 中的图像 2,2
    • Use the metal spudger to pry from the top left corner of the headphone jack/lower speaker assembly.
    • Gently lift the headphone jack/lower speaker assembly free of the device.
  7. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 步骤 7 中的图像 1,1
    • Locate the top speaker.
    • Use a plastic opening tool to disconnect the green-gold upper speaker connector from the motherboard.
  8. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to pry the uper speaker up and away from the device.
结论
8等其他人完成本指南。
Trent Chapman
于10/01/15注册
1,378 声望
创作了3篇指南
团队
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G15
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 3,336
