跳转到主内容
Samsung Galaxy Tab S 8.4 Back Cover Replacement
你所需要的
  1. Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Back Cover Replacement: 步骤 2 中的图像 1,1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Back Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover after the entire rim is disconnected.
结论
12等其他人完成本指南。
Tara Fussell
于10/01/15注册
984 声望
创作了2篇指南
团队
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G15
4 名成员
创作了12篇指南
3条评论
This is great and the process works fine. The query is where does one purchase a new back cover
Alan - 回复
Hi, where can I buy the back cover of Samsung galaxy tab S 8.4. Tnx
Abe Madrigal - 回复
Hi, where can I buy the back cover of Samsung galaxy tab s 8.4. Ty
Abe Madrigal - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 16
过去 30 天: 59
总计 13,322
