跳转到主内容
Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement
你所需要的
  1. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement, Stereo Speakers: 步骤 1 中的图像 1,1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
  2. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 2 中的图像 2,2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on the top part of the speaker.
  4. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 4 中的图像 2,2
    • Using your fingers, carefully remove the tab that connects the speaker to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 5 中的图像 3,3
    • Using your fingers, gently remove the speaker from its place.
  6. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on top of the speaker.
  7. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 7 中的图像 2,2
    • Using your fingers, lift the tab that connects the speaker to the mother board.
  8. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 8 中的图像 1,1
    • Using a nylon spudger, gently lift the round piece that connects to the speaker and remove it from its place.
  9. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 步骤 9 中的图像 2,2
结论
Mario Montoya
于09/12/16注册
225 声望
创作了2篇指南
团队
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 的会员
USFT-LACY-F16S9G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 621
