跳转到主内容
Samsung Galaxy Tab Pro 8.4 Motherboard Replacement
你所需要的
  1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 5 中的图像 1,1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 7 中的图像 3,3
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 步骤 8 中的图像 3,3
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
终点
5等其他人完成本指南。
victor johnson
于10/05/16注册
242 声望
撰写一个指南
团队
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 的会员
USFT-LACY-F16S9G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,351
