跳转到主内容
Samsung Galaxy Tab Pro 8.4 Charging Port Replacement
你所需要的
  1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 2 中的图像 2,2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 3 中的图像 2,2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 4 中的图像 1,1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 5 中的图像 1,1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: 步骤 6 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: 步骤 6 中的图像 2,2
    • Remove the two 2.5mm Phillips #000 screws.
  7. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 步骤 7 中的图像 3,3
    • Gently pull up on tab that connects the charging port to the motherboard
结论
5等其他人完成本指南。
Jonathan Romine
于09/12/16注册
1,072 声望
创作了2篇指南
团队
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 的会员
USFT-LACY-F16S9G2
4 名成员
创作了10篇指南
3条评论
Thank you for your help. You are awesome :-)
Kim Williams - 回复
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Brandon Torzeski - 回复
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 4,038
