跳转到主内容
Samsung Galaxy Tab Pro 8.4 Battery Replacement
你所需要的
  1. Samsung Galaxy Tab Pro 8.4 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: 步骤 2 中的图像 2,2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Battery Replacement: 步骤 4 中的图像 1,1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Battery Replacement: 步骤 5 中的图像 1,1
    • The battery should be completely disconnected and the new one can be installed.
结论
21等其他人完成本指南。
Jonathan Romine
于09/12/16注册
1,072 声望
创作了2篇指南
团队
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 的会员
USFT-LACY-F16S9G2
4 名成员
创作了10篇指南
一条评论
Samsung Galaxy tab ki battery 4800 mah
Razwan good ashqui - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 23
总计 12,082
