跳转到主内容
简介
This guide will show how to replace the motherboard on the Samsung Galaxy Tab Pro 10.1. The process will involve removing the rear panel, battery cables, and the battery. The front and rear cameras will also need to be removed to access the motherboard by itself. Then, the steps to remove the motherboard for replacement will be outlined.
  1. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Panel: 步骤 1 中的图像 2,2
    • Be gentle, the front panel is connected to sensitive wiring that may snap if too much pressure is applied.
    • Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
    • Go around the entire crevice with the plastic opening tool.
    • Set aside the separated front and rear panels of the device.
  2. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Battery Cables: 步骤 2 中的图像 1,2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Battery Cables: 步骤 2 中的图像 2,2
    • Remove the six 4 mm Phillips #00 screws that hold the battery in place.
  3. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the tape that runs along the length of the battery.
    • Lift the retaining flaps of the ZIF connectors on each side of the battery connector.
    • Remove the two ribbon cables that lay across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
  4. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a plastic tweezer and remove the top center 6 pin power connector that is attached to the edge of the motherboard.
    • Detach the battery by gently lifting the battery out of the panel.
  5. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: 步骤 5 中的图像 1,3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: 步骤 5 中的图像 2,3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: 步骤 5 中的图像 3,3
    • Use plastic tweezers to carefully detach the front-facing camera from the motherboard.
  6. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: 步骤 6 中的图像 1,3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: 步骤 6 中的图像 2,3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: 步骤 6 中的图像 3,3
    • Use plastic tweezers and carefully detach the rear-facing camera from the motherboard.
  7. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Remove the five ribbon cables holding the motherboard together with a plastic tweezer.
  8. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the Phillips #00 screws from the plastic part holding down the motherboard.
  9. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Gently lift the motherboard from the front panel enclosure.
结论
4等其他人完成本指南。
Stephen Yeung
于2015年08月26日注册
1,490 声望
创作了6篇指南
3条评论
very useful,thanks a lot.
Singh
bandna kaur matta - 回复
ارغب باصلاح شريحة الاتصال
mazinmandour - 回复
Thanks for this manual. Can you help me recognise the Wifi/BT module? I have a problem with that - with some luck it is just the connector....
Arno - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 24
总计 6,104
