跳转到主内容
Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Rear Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Rear Panel: 步骤 1 中的图像 2,2
    • Be gentle, the front panel is connected to sensitive wiring that may snap if too much pressure is applied.
    • Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
    • Go around the entire crevice with the plastic opening tool.
    • Set aside the separated front and rear panels of the device.
  2. Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: 步骤 2 中的图像 1,3 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: 步骤 2 中的图像 2,3 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use plastic tweezers to carefully detach the front-facing camera from the motherboard.
结论
3等其他人完成本指南。
Stephen Yeung
于08/26/15注册
1,547 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,080
