跳转到主内容
Samsung Galaxy Tab E Lite 7 Kids Battery Replacement
你所需要的
  1. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 步骤 2 中的图像 2,2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: 步骤 3 中的图像 1,3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: 步骤 3 中的图像 2,3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to gently lift black ZIF (zero insertion force) connector shown within the red square.
    • Now gently pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
结论
5等其他人完成本指南。
Nicholas Nolan
于02/17/17注册
805 声望
创作了5篇指南
团队
USF Tampa, Team S19-G2, Hoffman Spring 2017 USF Tampa, Team S19-G2, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G2
4 名成员
创作了7篇指南
一条评论
Great information.  You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
Paul McWilliams - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 3,026
