跳转到主内容
Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement
你所需要的
  1. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Back Casing: 步骤 1 中的图像 1,1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: 步骤 3 中的图像 3,3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Locate the speaker in the top right corner of the back casing. Use a pair of tweezers to pull peel up the film connecting the speaker to the case.
  5. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: 步骤 5 中的图像 2,2
    • Once you've detached the film connecting the speaker to the case, use the tweezers to remove the speaker completely.
结论
Dave Dorzback
于09/28/16注册
626 声望
创作了4篇指南
团队
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G4
3 名成员
创作了14篇指南
2条评论
Then what? How does this fix the problem? Can I tweek the speaker? Do I buy a new, more powerful speaker? What is your point in this post?
Janet - 回复
@Janet Sorry I know you probably wont even see this, but its to help those who wish to replace a broken speaker, its not about implanting a 9” subwoofer. Sorry but sometimes the simplest of explanations will often answer your questions.
sannas30 -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,363
