简介
Front panel removal for the Samsung Galaxy Tab E Verizon.
你所需要的
Turn the device over so the screen is facing down. Locate the front panel assembly connector at the top left corner of the motherboard.
To remove the connector, first use a pair of tweezers and flip the connector lock upwards towards the battery.
Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
You will need to wedge a plastic opening tool in between the front casing and the screen. Then move the tool around the perimeter of the device to break the adhesive.
Once you've loosed the front panel enough with the prying tool, you can use your hands to pull the front panel off of the device.
6等其他人完成本指南。
