跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. If the device has a micro-SD or SIM card inserted, remove them from the device before continuing.
    • If the device has a micro-SD or SIM card inserted, remove them from the device before continuing.
    • Verify your device is turned OFF after removing all external peripherals from it. Power down the device if it's turned on.
  2. Insert a plastic opening tool in between the edge of the device's screen and its back cover. Once the tool is wedged between the glass and back casing, move the tool around the edges of the device to undo the plastic clips holding the casing attached. Inserting the tool and prying off the back casing requires a good deal of force. If you're having trouble undoing the clips, try using a suction cup on the screen to increase separation with the back casing. Inserting the tool and prying off the back casing requires a good deal of force. If you're having trouble undoing the clips, try using a suction cup on the screen to increase separation with the back casing.
    • Insert a plastic opening tool in between the edge of the device's screen and its back cover. Once the tool is wedged between the glass and back casing, move the tool around the edges of the device to undo the plastic clips holding the casing attached.
    • Inserting the tool and prying off the back casing requires a good deal of force. If you're having trouble undoing the clips, try using a suction cup on the screen to increase separation with the back casing.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. As more clips are undone, it will become easier to further separate the device from its casing. Once you're able to separate roughly half of the device from the back casing, use your hands to gently pull the back cover off of the device. Don't forget: after creating some separation between the device and back case, you can use a suction cup attached to the screen to aid in pulling the device apart. Don't forget: after creating some separation between the device and back case, you can use a suction cup attached to the screen to aid in pulling the device apart.
    • As more clips are undone, it will become easier to further separate the device from its casing. Once you're able to separate roughly half of the device from the back casing, use your hands to gently pull the back cover off of the device.
    • Don't forget: after creating some separation between the device and back case, you can use a suction cup attached to the screen to aid in pulling the device apart.
  5. The front camera is located at the top middle of the motherboard as shown in the picture by the red rectangle.
    • The front camera is located at the top middle of the motherboard as shown in the picture by the red rectangle.
  6. In order to remove the front camera you must first remove the ribbon wires connecting the camera to the mother board. To do that you need to use tweezers to flip a black latch away from the camera, towards the bottom of the tablet. This latch being flipped up will allow you to pull out to ribbon wiring easily. Once the ribbon wire is removed, pull the camera out.
    • In order to remove the front camera you must first remove the ribbon wires connecting the camera to the mother board.
    • To do that you need to use tweezers to flip a black latch away from the camera, towards the bottom of the tablet. This latch being flipped up will allow you to pull out to ribbon wiring easily.
    • Once the ribbon wire is removed, pull the camera out.
结论
William Gorham Jr
于2016年09月28日注册
57 信誉积分
创作了2篇指南
团队
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G4
3 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 8
总计 470
