当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove any micro-SD or SIM cards before continuing.
Verify your device is turned OFF.
Disconnect all external devices from your tablet.
Insert the plastic opening tool by wedging it between the device's screen and back cover.
Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
This step may require more force than expected. If difficult, try using a suction cup on the screen.
This process will become easier as more clips are separated.
Use your hands to gently pull the back cover off the device after about half of the clips are separated.
A suction cup can be used in this step as well to assist in pulling the device apart.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
