跳转到主内容
Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement
你所需要的
  1. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement, Back Casing: 步骤 1 中的图像 1,1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 步骤 3 中的图像 3,3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
结论
Dave Dorzback
于09/28/16注册
626 声望
创作了4篇指南
团队
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 12
总计 2,666
