跳转到主内容
Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement
你所需要的
  1. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement, Back Camera: 步骤 1 中的图像 1,1
    • Make sure the device is turned off.
    • Using the plastic opening tool, start in the center and wedge the angled tip between the plastic back and the scree.
    • Try to pressure it, wedge it back and forth.
    • Do not wedge the plastic opening tool directly on top of the power buttons and headphone buttons.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 步骤 2 中的图像 2,2
    • Once the bottom edge has been loosened, use the suction tool to pull it.
    • The second picture shows the internal portion of the tablet once the back cover is removed.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 步骤 3 中的图像 2,2
    • The first picture shows the location of back camera.
    • Disconnect the rectangular connection from the back camera to the motherboard.
  4. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 步骤 4 中的图像 2,2
    • The picture illustrates what the device should look like once the back camera is removed.
结论
Tingting Liu
于09/28/16注册
25 声望
撰写一个指南
团队
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 1,259
