当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Make sure the device is off and the SD card is removed before taking off the back casing.
Use the tweezers to flip the switch of the connector.
Lift the connector from the motherboard.
This connector does not come completely off, but disconnects from the motherboard.
Use the tweezers to flip the switch of the blue connector on the motherboard.
This switch can detach from the device, but just needs to disconnect from the motherboard.
Ensure the blue ribbon cable is not under the motherboard upon reassembly.
Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
